ITS OVER
RyanbabZ71
Well my college career is finally over (well at least for my BS degree  :chevy: ).  Had my last final today.  It feels pretty good.  Still hasnt set in though.
Oh...It will set in...As soon as you start putting the $$ in the bank.
But it will be 6 months before you can play hooky. :)
Congrats, and good job! :chevy:
:thumb:
I hope you do more with your degree than I did with mine...  Congrats on the accomplishment!!!
:thumb:
Ditto (although it will be hard to do less)!
Congrats!
Congrats Ryan  :thumb:  :chevy:
I've still got a week or two left in the semester and a few final projects to get done, but I could do those in the course of one evening (probably the day before class :) )
Feels good?  If it was sunny outside and I could wash my truck  :chevy:
I am awaiting a phone interview.  These are wierd I havent brushed my teeth and I am still in my PJs  :)
it does feel good for all to be over.  I finsished up yesterday at 6:30 and your right it hasn't sunk in yet, or it could be that I'm so excited I'll finally be making enough $$ to buy a new truck.  just remember nothing's final till they give you the diploma :chevy:
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
