Smittybilt M1 Black Mesh Grille
Does anyone here have the Smittybilt M1 Black Mesh Grille? P/N# 615823 I am having trouble finding if it is a one piece or two piece insert, It shows a 1pc when ordering but I have yet to see a 1pc in pictures. Any help is appreciated!
