Just a vent
MadFish
I hate people who cant admit they're F^*%ing wrong. I really hate it when you prove them wrong and they still wont admit they're wrong. My f!@$ing manager this morning had a case of juice the order # on the box and tag are the same. The place on the shelf is for the 48oz. We get the 64oz., well the 64 is taking place of the 48oz. I tell him, show him, have someone else show and tell him. And all he does is change our words to make it sound like he is still right :angry: But, he is still wrong and wont F#$%ing admit it. Then he's starts telling me I dont know what Im doing or taking about. I have been doing this job for 6 years, he's been around 6 months. I was a night stock manager. I trained him on how to be a night stock manager(obviously didnt do a very good job at either). And I dont know what Im  F#$#ing talking about or F$%#ing doing. Who the F!@@ is he to say Im not doing my d@#$ job right :angry: I have put up with his smart-a$$ed comments, stupid mistakes, constaint B@#$%ing, and all the other crap he pulls. And all it took was a case of F@#$ing Cranberry Juice to piss me off. Maybe its because I have about 22 days left until my last day of this F$#@ing job. I dont know, but Im sick and tired of putting up with his BULL$#!T.
Now that I have gotten some sleep, I have cooled off. Im just glad he is out of town until monday night and tonight is my night off. Im going over to a friends and I am going to drink myself sober :thumbs: I got 2 cases of beer, some JD, and some Wild turkey behind the pass. seat of my truck right now.
Mike, Keep away from my truck :P
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
