RPO Codes - 2002 Silverado
My girlfriends dad is looking at buying a used '02 Z71.  Is there a place where I can find out what all the RPO codes mean?  Specifically, I am trying to figure out weather or not it has a locking rear diff.
Thanks.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
