Weird steering creak/ Groan (video)
Wow, that's certainly noticeable. Does it sound like it's internal to the cab or external to the engine area? What is the condition of your power steering fluid?
does that year have a rack...if so i would check the bellows on each end of the rack. also check if ps fluid is contaminated
  • 4 weeks later...
you may find this strange but these are known for the steering shaft from under the dash to the box to go bad. You can remove it from the steering box and slide the shaft in and out but it will come back. This moves the grease around inside the shaft. Dorman makes a replacement shaft. About 60 dollars.
