a ricer's story
Twas the night before Christmas and caught at the light, Was a domestic V8 and no cops in sight, I will try, I will try, I will try with this small motor, To beat this 1500, even with it's big Motor, As light goes green and I pull like no joke, The 1500 erupts in clouds of tire smoke, Now Smasher, now Rev-ver, now Stroker, now Blitzin, These are the names of my four VTEC pistons, Racing ahead I'm the Star of the action, But I know I'm in trouble when that V8 gets traction, Grabbing second, I hear the RPM sing, My mirror is blocked by my Shopping Kart Wing, I now hear the roar, of that big monster gaining, All I can do is keep that four-banger straining, In a second, the shockwave hits with a blast, And my stickers go flying now, a thing of the past, Don't bother with third, cause now it's too late, Just try to act cool, like you can relate
MERRY CHRISTMAS!!
:owned:
:crackup:  :wtf:  :wtf:
Oh, that's sweet !!
:D  :smash:  :fume:  :smash:  :smash:  :smash:  :smash:  :smash:  :smash:  :smash:  :smash:  :smash:  :smash:
IMHO, the only thing that I did'nt want to see in both FNF and the previews for 2F2F, were the uncalled-for destruction of the Charger, Rustang, and the Vette
:nono:  :nono:  :nono:  :puke:  :nonod:  :nonod:  :fume:
Just my $.02 centavos. Do I need a reciept for that?  :D
