Squeeky Leafs?
Txjose
So my girl has a very early 2014 silverado crew cab 2x4 texas edition.
She took it in to the dealer to gave it looked at since it has a warranty still.
She has a pro comp level with BFG Ko2s 275/60/20s...they gaver her the run around about the level and when she got it back this is what they said.
Try another dealer or remove the level and take it back?
Sent from my Note 4 on Tapashit
Your level has nothing to do with this. Go to to another dealer. my old 2014 was so bad about all kind of rear noises, and squeaks. They replaced both leaf springs, shocks, etc over 7 visits. Never fully went away. I finally traded for a 2016.
That's what i tild the Gf..... How would the level throw off the rear?
I told her to have her sister shake the rear amd crawl under it to see if she can locate the squeeky part. She is almost certain its from the leafs.
We have the same level installed the same day by the same shop maybe 20min apart. Mine is dead silent, and thats also because mine has over 50K....she just tipped 10K on her 2014 lol
My 14 sierra originally had noisy Ranchos in the back and bilsteins solved that. Then I noticed the leafs were squeaking. Sprayes it with fluid film and it's been perfect. I spray it every once in a while when they look dry
Where did you spray??
Even though the level has nothing to do with the problem you are still adding something that the truck was not designed for and the dealership/GM has every right to deny warranty work because of it.
Yah i know that but thats like saying the window motor went out because of the tine that was added makes the window heavier.
We are going to remove the level re align the truck and take it back. Hopefully they dont blame the "oversized" tires. Lol
275/60/20 ia not the same as having 35s
    250.3k
    Victorlani
    Victorlani
  • Who's Online   4 Members, 0 Anonymous, 344 Guests (See full list)
