285/55/20, without level/lift
jstewart
Great info! What would these forums do without helpful folks like you?
"Subjective" experiences from people that are running these tires would be outstanding! 2014+
How was clearance for you without level? Was planning on a 275/60/20 but prefer the width over height with the 285/55/20.. Don't personally know anyone running them so was hoping some had their experience to share.
No different than stock. They're just a wider tire, not taller. I feel like they're perfect for what I wanted.
IMG_20160122_1610352.jpg[/url]
I run 285/55s on my truck. Just felt like being a dick I guess. My situation is somewhat different as my wheels are 20x10 with negative offset. 2.5 level. I would think this size tire would rub at stock height on stock wheels, especially with the aggressive lugs on the RT.
Sent from my Nexus 6 using Tapatalk
Pickup looks awesome, those wheels are spot on.
I might have to just bite the bullet and get some adjustable bilsteins. My shop seems to think they'll fit bone stock so we are going to give it a whirl this week.
A 285/55/20 will be taller AND wider than the stock 275/55/20. The difference isn't much, but they're larger than stock.
Mounted tires today, no rubbing. 'Twas dark before I could get pictures, but there is plenty of room.
Ended up with 285/55/20 Toyo At2s, not r/t. Although, I think the r/t would also fit without issues.
  • 4 weeks later...
dowrk... did you put those tires on stock 20" wheels or aftermarket? I have the stock 18" wheels and tires on my truck 265/70/18 and comparing this 285/55/20 size the overall tire is very close... and based on your experience it fit. I need to replace my 18" wheels with 20" wheels so I am trying to figure out if I should buy 20 x 9 or 20 x 10 wheels?
Truck looks great! What's the -offset are your wheels?
If I remember right, the recommended is 20x9 for these tires. I couldn't tell you if 10" would cause you issues or not, I would think it would just all depend on your offset. Mine are on the stock all terrain 20s.
    DNL going
    DNL going
  • Who's Online   5 Members, 0 Anonymous, 510 Guests (See full list)
