How's Everyone Doing?
R Dogg 56
Hey Everybody !!!
R Dogg 56 from Minnnesota here, and I gotta say that this place is SWEET !!!!  :)  :cheers:
Keep up the great job, and I'll see ya'll around. :chevy:
Just thinking about Minnisota gives me a chill. Brrr
The mentioning of a chill makes me think of beer....mmmmmmmmmmm.
Welcome aboard R DOGG.  :)
<font color='#000000'>Just thinking about Minnisota gives me a chill. Brrr</font>
<font color='#000000'>The mentioning of a chill makes me think of beer....mmmmmmmmmmm.
Welcome aboard R DOGG.  :D</font>
That.........and the Vikings Cheerleaders !!! :eek::cool::seeya:
<font color='#000000'>Hey Everybody !!!
R Dogg 56 from Minnnesota here, and I gotta say that this place is SWEET !!!!  :cheers:  :chevy:
Keep up the great job, and I'll see ya'll around. :lurk:</font>
Where are you from? I live in Eagan, MN... Do you have a truck?
I'm from Waconia, about a half hour SW of Eden Prairie. I don't have a truck right now, but I hope to have one after I graduate from college in a couple years.
Political Science major, Law school after. :chevy::cheers:
BTW: HOpe everyone has a safe and enjoyable Memorial Day
:lurk::thumbs::devil::devil::):):flag::flag::flag::flag::flag::flag:
Political Science major, Law school after. :lol::D
:lol::lol::lol::flag::flag::flag::flag::flag::flag::flag::flag::flag:
I dated a physics major, then she went to law school after that. 8 years straight at UNC at Chapel Hill NC.
Welcome abord. :smash:
