Do I have to have E rated tires?
Doug64
If all I do is tow a 3k lb trailer? I never load anything super heavy in the box.
  • Replies 39
Most places won't install tires that are under what is stated on door jam.
That's what I'm expecting to happen.
You won't have to worry about it at all I had 275/60/20s and that's a p metric tire and I used to tow my loaded dump trailer all the time and no issue !!
You'll probably be fine with an 8-ply, D-range tire...but I really wouldn't want to limit your capabilities with a lighter tire than that. I would hate having a 2500HD that I couldn't use to it's full potential (if the situation called for it) just because of the tires. A E-range tire will be more stable while towing and hauling anyway.
You need to know the actual weight of the axle that the tires will be on (fully loaded) and the max tire capacity for whatever you choose. Doubt any tire shop would actually mount them for you on the truck.
Even a p metric tires are good for 2400lbs a piece so u are more then fine with what ever tire you want they just wear a lil faster that's all and any shop will put them on your truck no issue I towed a 12 k excavator and had zero issues so no worries.
Thanks for all the input. I've decided on 275/65r20, but now I've become obsessed with which tire I want. I really like the Trail Grappler but damn they're expensive. So I'll probably settle for the Cooper AT3.
Since my original post I've looked at so many tires, I've gone tire blind.
Trail Grapps and AT3's are drastically different tires. What type of tread are you really wanting? MT or AT?
I love the looks of an MT but an AT is much more practical for my needs. My truck is my dd and I pull my tt a few times in the Summer months. Also I go fishing in the mountains and some snow day-trips.
Roger that. Yeah, you probably don't NEED a mud terrain then...although I agree that they look awesome. I'm in the same boat. I prefer the look of MT's, but don't need them on my daily driver that sees long interstate trips pulling my camper...and only goes off road a few times during hunting season. I ran Cooper AT3's before my current Toyo's, and I was happy with them. My only complaint was that they looked pretty tame. IMO, even though my Toyo's have a similar tread design, they look more aggressive than the Coopers because of the sharper tread blocks and more aggressive sidewall. I feel the same about the new BFG AT's, they look more aggressive than they really are, because of the sidewall design. I'm seriously considering a hybrid tire, like either Cooper Discoverer ST Maxx or Toyo Open Country RT for my next set. They look more aggressive than an AT, without all of the negative effects of a true MT.
I do like the looks of the Cooper ST Maxx but not the price. As I sit now, no matter what I buy, it's going to have to be one tire at a time, like every other payday.
The Toyo AT2 is a great looking tire but I can't do the nearly $1200 for a set. I'm starting to regret buy 20" wheels.
Yeah. 20" rims and tires are a bit more expensive than the 18" versions...but they look good, haha
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,276 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
