2013 1500 axle shaft problem
Hello. I just purchased a 2013 silverado LT 1500 ext cab off an auction. The truck was in a accident and had some damage. I ran into a problem with the rear axle shaft. The plate where the studs are is bent, so the spare wheel just wobbles, it actually destroyed the orginal wheel from the accident. I have removed the shaft. But when I called the dealership to order a new one they advised there was to options a 8.5 axle shaft or a 9.5 axle shaft. Even with running the trucks vin number it gave them two options. What would I need to measure on the rear def or axle shaft to know which one to purchase. Thanks Eli
What engine is in the truck? Does it have drum or disc in the rear? The VIN should give them some limitations when they search in the catalog and narrow down which axle is in it.
wow thanks! How are you able to figure that out? Just for my own knowledge....
I work with them every day lol. Parts catalog does tell, just got a find a guy who can interpret it good haha.
2007-2013 5.3 trucks are 99.9% equipped with the 8.625" axle. The only ones that use the 9.5" axle are 6.0 Vortec Max and 6.2 equipped 1/2 ton trucks. Both Vortec Max and Max Trailer package trucks (6.0 and 6.2 engines) all have rear disc brakes. No 2007-2013 4.3 and 5.3 truck is equipped with rear disc brakes, all are drum. If its 2007-2013 with rear drum? 8.625".
    • Monday morning 2.99 here and Tuesday leaving work it was 3.59
    • This 2 wheel RWD right? I had an 88 4wd S10 Blazer. Stock lift. After moving out of areas where 4WD was necessary, the next tire set was a passenger car type tire. Wasn't going to drive it much didn't want to put a large amount in tires. But it did look a little goofy with that highway tread design   I had really good luck with Hankook tires.  1 set for 1/2 Chevy PU. 1 set for Toyota Sienna and 1 for Lincoln town car. They all performed well. Pleased with the performance especially on the Sienna. The Kinergy replaced the model I had on all 3.   Cooper makes a good tire, I like the look of the tread since it does look a more "off road" ready.  I'd probably pick the Cooper for the looks   Any rebates on anything?   Used to be Discount Tire was the place to buy at any Holiday. They had specials/rebates etc... on sets. Haven't seen anything like that done in a good while. Just a manufacturer rebate occasionally
    • For a limited time, Preferred Customers and online/catalog customers get a free magnetic level with their order of $100 or more when they use code LEVEL726 at checkout. Offer ends July 28, 2026.     Save up to 25% off retail as a Preferred Customer.  Sign up here.  https://www.amsoil.com/p/preferred-customer-registration-preg/?zo=521390   As always you can order here.  https://syntheticadvantage.com
    • Looking at cheap tires for this project '95 Blazer. I'm seeing all sorts of brands I don't recognize. 235/75/15 are the size I'm after.   "Dirt cheap" (<$100/each) Starfire Solarus (AS or AT) Rocky Mountain HT2  Mohave HT Westlake SU318 H/T Laufenn G FIT Entry Level AS (yes, Entry Level is the name of the brand!)   "Somewhat cheap" (<$150/each but >$100) Kumho Solus TA51a Ironman (Les Schwab) Cooper Discoverer RT AT Hankook Kinergy ST (H735) Milestar Patagonia H/T Toyo Extensa AS II   The only one that stands out is the Cooper Discoverer in looks and actual brand recognition for me. $120/each. The buyer for this truck will probably want a visual look of not a completely smooth car/highway tire and this one has slightly blockier tread.   Starfire is supposedly a sub-brand of Cooper. Mohave is a house brand of Discount Tire. The spelling bugs me, I've always known it as Mojave. Kumho, the name, still makes me giggle.   If I was selling it tomorrow, I'd probably go with anything in the Dirt Cheap category. But I may drive this around through the fall and my mind would be ruined knowing I'm rolling around on "Laufenn" or "Entry Level" tires, name alone.   In a world where *most* tires are now offshore-produced, is one low-buck tire much better than another?
    • Most vehicles have engine covers. The cooling fan’s are below the cover. That probably doesn’t help. I cleaned collector car engines. The rest not so much since the last one protested by missing for a few days drying out.
