1500fp's Silverado 1500 working dog cruiser
1500fp
Here is a parts list of some things i have bought, still researching a few others before buying:
200Amp Stinger Isolator - http://www.amazon.com/gp/product/B001HBYXVS?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
Dometic CF-050 Fridge/Freezer - http://www.amazon.com/gp/product/B0017YHGXC?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Battery Hold Down Block and Bolt - http://www.amazon.com/gp/product/B000CO8ZJM?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00& http://www.amazon.com/gp/product/B008Y8KKM8?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
2" Gel Memory foam mattress topper - http://www.amazon.com/gp/product/B019J9AUZW?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=APCUWEOU23BHI
I could have gotten away with a full size but the full XL (which is a little longer) was only a few bucks more and was amazon prime which would ship in 2 days, i also figured i could use the trimmed off section for my dogs bed.
  • Replies 39
0 gauge stinger cable for battery connections.
12 gauge wire for starter connection on isolator.
Got a handful of connectors needed, some terminal blocks as well.
Going to run 4 gauge into the cab terminal block, then off that 10 gauge to the fridge and 8 or 10 to an inverter when I get one in the future.
Ok more parts list :)
15 AMP Auto Reset Fuse (for dometic fridge, nice so if it blows you dont have to keep putting a new fuse in): http://www.amazon.com/gp/product/B00FRHS2BK?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
10 Gauge Power Quick Connects (these are good for hard wiring devices in the truck, cig outlet plugs are a really shitty connection these are much better): http://www.amazon.com/gp/product/B00HCRJUQ4?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
2x Knukonceptz 4/8 gauge power distribution blocks (for splitting power input in the cab to go to fridge and an inverter, via 10 or 8 AWG wire): http://www.amazon.com/gp/product/B0071GKSL2?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
2x Knukonceptz Battery Terminals (these are nice since i can run multiple outputs from the same connector.) - http://www.amazon.com/gp/product/B00JK9FTLC?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
Group 48 AGM Die Hard Battery - http://www.sears.com/diehard-advanced-gold-agm-battery-group-size-48/p-02850748000P
Pics of 2nd battery install into tray, pretty simple. Drop it in, slide under the lip on the right, then screw down the holder block on the left side.
Tools Required:
13mm socket with a LONG extention, or a stubby screw driver
more pics
Designed some 3d printed brackets that i will use to bolt the fridge down in the back. The grey piece of plastic comes with the fridge and is part of the handle (there are 2 of those plastic blocks screwed into the fridge with a metal tube in between for a handle on each side).
More pics since this stupid forum has such a small attachment size cap.....
For those wondering where the factory GM wire tracks are, here ya go. Very easy to access, pull up on the panel then back, pops right out. Then pry the clasps off the black plastic cover over the wire bundle.
This is where I will run my 4awg power lines to the back seat area
Fridge and back wall are now securely mounted.
I bought some U bolts for the 3 brackets that the factory seat hooks go into, and then some L brackets to secure it to the floor.
Then i bent some steel stock into a little J shape to keep the fridge in place. I though I was going to have to bend them at the end as well, but this design is holding up fine in my test drives on the highway and local roads.
In order to get the fridge off the mounts, you have to slide it perfectly straight for about 1/2 to 3/4 of a foot, and since there is soda and food in side and its sitting on carpet.... that's not going to be happening by itself. If you slam the brakes the natural motion the fridge wants to do is tip, which actually keeps it in place, there is maybe 1-2mm of slack in the brackets so it doesnt move a noticeable amount but enough to have some free play to easily slide it in and out when removing.
Will try and get more pics up soon.
OK here are a bunch more pictures of the setup.
250A fuse going between the power lines on the batteries, and the power line feeding into the cab.
Made a bracket out of some steel stock for the stinger, just bent it with a hammer on a vise.
Pro-tip on running the cable thru firewall: allow enough slack so you can make a dip in your wires, if any water does get in the hood gravity will take it to the lowest point of the wire, so make sure the lowest point is not the nipple on the firewall housing!
U bolts holding the back wall in place, and the custom brackets i made for the fridge with the fridge removed.
Also a nice pic of all the snow i woke up to this morning, gotta love new england! (my truck was covered this morning with 6 inches)
more pics due to stupid upload limit
U bolts holding the back wall against the truck.
Custom mount made from steel stock bent in vise to mount the stinger to the frame bar under the hood.
Negative Terminal Connections on the Stock battery.
Photo showing the dip in the wires going thru firewall (kind of hard to tell from angle)
Fridge brackets, used those little things where you drill a hole into a piece of wood then hammer it in from the back and it gives you a little screw hole to thread into (not sure what they are called).
Metal piece is just metal stock from home depot i cut to length and bent in a J shape in the vise, you just slide the fridge back until it meets the wall and you are good to go. Because of the tightness in the plastic mount on the fridge, and the fact that the weighted fridge is on carpet, it cant slide off the metal bars without human power. When you brake it naturally tries to tip and jams itself in place.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
