Speaker singal in rear
I am looking to soon upgrade the system in my 2014 single cab. I would like to pull the signal from the rear speakers to avoid the loud amped chime but I am trying to find out if the signal sent to the rear speaker is full range. Does anyone know?
If they are full range, my plan is to grab that single for the components to add to the doors. Leaving the factory dash speakers for chime.
I know I will lose fade function and I'm okay with that.
62 views, no one answered you. Here's what I know, for the standard audio system, there is a full range signal to all speakers with the dash speakers getting a HPF. Even amplified, the door chimes and turn signal when coming out of the front door is not that bad, it's just the amplified dash speaker that becomes really obnoxious.
Ok to lay it all out, I plan to run a set of Hertz comps with the mid in the door and the tweeter in the sails. I was going to run the factory signal to a DQ-61 then to the amps (still undecided). Most likely and BMmk 12 for the lows. I am also planning on leaving the factory dash speakers untouched and hooked to the factory amp.
Your saying I can front the front signals to the processor and use those for the front amp and sub amp without the chimes being overwhelming from the component sets? Just trying to get this all clear. Don't want to put all this in and have the chimes so loud that they are unbearable.
Tech1451,
I just did the install on my 2014 Chevy Silverado 1500, I have the 8" Mylink touch screen without the bose. I asked the exact same questions you were asking, and the information just is not available. Chevy can't answer it, no one on this forum could answer it. So I did the only thing any sensible person who wants to install an upgraded sound system in there car could do...
I bought a $400.00 Oscilloscope and measured the output myself, what I found was quote interesting:
For the most part the signal is flat, however the stereo has some interesting characteristics. Using 0 DB test tones from 80 HZ to 16000 HZ, I played each track and checked the response on the scope. The stereo clips at max volume with 0 DB test tones between 80-125 HZ, again from 315-500 HZ, again at 1250 hertz and again at 12500 hertz. I set my volume 3 "clicks" of the volume knob lower and the signal produced cleanly throughout the entire range. The signal from the front to the rear is identical.
That being said, music is rarely played at 0 DB due to the fact that most mastering is done below 0 DB.
The stereo only has 4 speakers with the front dash speakers being tapped off the front door speakers, So if you want to keep your factory fade in tact, you can by tapping the signal from the front & rear doors.
As far as the door chime, it is absolutely deafening at 60 watts and the tone volume set to low. You can hear it from 40 feet standing outside the truck with all the windows/doors closed. That being said, I'm running 4 60 watt tweeters and 4 60 watt mids.
The signal cannot be turned off due to the canbus/gmlan that is used to transmit data from the radio to the BCM. However some clever people have intercepted the signal and filtered it using a micro controller and were able to change it that way.
If I get some time this weekend, I'll run the tones through the scope again and screenshot them all so you can get a better idea.
Good luck on your install, I just hope you know what you're getting yourself into. I started mine December 27th, It's still not finished, but I'm a perfectionist.
Hope this helps!
He pretty much laid it out for you. Problem with amplifying the front channels are the high pitched door chimes, especially if amplified at the dash, just puts too much chime sound in your face. So yes, if you take the signal from the rear, split it to feed both rear and front speakers (door or components), you will get a full range sound. I will tell you, it doesn't take a whole lot of power to get to a deafening sound level in a truck, especially these with how quiet the cabs are to start with. Upgrades in mine are really simple, lower power and basically low tech, but you would absolutely not believe the sound quality and sound stage I've been able to achieve.
Front Doors Alpine Ty-R 6x9 coax, 120hz HPF
Rear Doors Alpine Ty-S 6.5 Components (mid in rear door crossed at 120hz HPF, tweeter in dash with inline crossover)
Alpine 445U (45x4) Compact Amp (tucked behind glove box, tied in via factory wiring and Metra harness adapters)
Kicker PT250 10" Sub with 100W built in amp
Sweet spot seems to be about 30% gain on all amps, factory head unit, run it with approx. 15% treble cut, 15% mid range boost, bass flat with a 10% fade to the front. Volume level on the head unit is good to about 60%, without a signal processor it gets a little dirty after that and honestly by then, it is deafening. Looking at 280 rms total power. I've had big systems years back that had 2-3 times that power level and didn't produce the sound we're getting in this truck. Will tell you, up to about 2 weeks ago, I was really disappointed. Added a small sub, set the doors to 120HPF (12db), added some mid range, cut back the tweets, all is good now.
You leave the driver side dash speaker to the factory wiring, it still supports the voice commands, chimes, etc
Here's a tip I figured out. Everyone typically set the gains on their amps the same way, they crank up the gain to 75-80%, then run the HU at a lower setting to maintain reasonable volume. Turn down the gain on the amp and chime volume will come down. At first had mine set the same way. Now, I set the gain lower (about 30%), and just listen with a higher volume on the HU
Amp gains are a way to signal match your head unit to the amplifier, they are not a volume knob, Google how to set gains with a multimeter and there are some great articles on the matter.
Also, the reason people set amp gains at 75% volume is to avoid clipping, a clipped signal sends DC voltage to the drivers which can damage your speakers. If you have a scope or a smd dd1, you can test for clipping easily, if not, you can use test tones and listen for it.
The front dash speaker is tied in with the front door speakers, if you tap the signal from the door, you're fine, if you tap it at the radio, you'll lose the dash speakers.
Which wire at the harness is the driver side dash speaker for on star phone etc.?
Not the best picture but it will give you the info you need.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
