2004 sierra 2500hd 6.0l heads
hello all-
looking to get rebuilt heads (317 casting) for my 6.0l and came across a pair of NEW heads for the same price. All the GM parts websites say I need part #12562319 heads (317 casting), the new ones I found are GM part #12562317 heads (also 317 casting). Does anyone know the difference (if any) between these two heads?
Everybody seem to say "all 317 casting heads are the same", true? Then why the different part #? The price difference between the two part # is almost double, and for the life of me I can't find out what the actual difference is. I would like to get the less expensive heads, but only if they are correct.
Any and all help is appreciated, thanks.
Don't know what the difference is but I would say there is a differece. If you go to gmpartsdired.com and insert the part numbers this was what came up.
The 12562319 were $384.80
The 12562317 were $197.77
that's my problem-
doug scott wrote: "they appear to be the same"
Duelin wrote:#12562317=$197.77 , #12562319=$384.80
-because if they are the same I would like to get the ones that are 1/2 price!! I've sent an email to gmpartsdirect.com asking for more info so hopefully they can explain it
thanks for the help, bill
that's my problem-
It may be that one is for gas and the other is for CNG. Given the volume of sales difference, I would expect the gas to be cheaper, but, it may also be that given the demand, GM is clearing out the CNG heads. The difference between the two is the materials the valve seats are made of and the exhaust valves as well I think.
  • 3 weeks later...
I just asked a bud of mine about this. He works in the machine shop of a well known, well respected and reliable engine builder in my area.
Stand by ....
It is assembled vs bare
Nope- both are fully assembled, but still no info other than that. I believe Doug Scott is probably correct, that they are CNG heads
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
