Mishimoto catch can?
Anyone use this brand? Ive read mixed reviews. I ordered the non baffled one up, not overly realizing the difference. I'm still a little unsure, is the baffled necessary? Otherwise looking at the design it looks well made, should be in the mail shortly.
I've been reading more and more on these DI engines and the grunge ppl are collecting with theirs and I've almost all but stopped driving my truck until this comes in.
I've put 4800kms on my 15 (bought at 5) so I'm thinking I'm going to get a intake clean out done also once it's installed
Sent from my SM-G900W8 using Tapatalk
