HID Flickering?
Hult
I have some serious problems with my HID's on my 2015 Silverado.
Mine currently flicker when I first start my truck and then only one will work (either side). If I turn the lights off and then back on numerous times, they will eventually stop flickering and both will turn on.
Say it's dark out and I unlock my truck from my key fob, both lights turn on without flickering. If I keep pressing unlock every few seconds to keep the lights on (to the point were they've finally warmed up all the way) then turn my truck on, sometimes they don't flicker and do just stay on.
This has been this way since my install, 6 months ago.. I do have a snowplow, so inside my cab they installed a switch to switch from the truck lights to the snowplow lights.
Do you guys think it may be something to do with this? I also heard flickering with HIDs in new vehicles is cased by the day time running lights. So you need to bypass that, or something..
Oh, and when I did install these lights.. I installed the low beams first. Typically, only one of the pair worked. I hate to rebuy another set! (Only one of the two in that box worked as well)
Then I installed the high beams a few weeks later. And the same ordeal, only one of the two worked! So, I had to buy each bulb individually at a hefty price of $60 each on Amazon. I did buy the Kensun brand, 55w.
Did anyone else have problems with them after the install? or even during?
Do you have a capacitor installed with a relay harness?
Nope, I do not
You will need a capacitor in the power source for both headlights due to the PWM pulse width modulated power for the DRL's and headlights it does that to make them dimmer during the daytime hours, if you use a relay harness then you will only need one and you will not have to hack up any factory wiring and also a lot easier. I bought mine from the retrofit source and it was all plug and play. Otherwise they will always flicker and you will damage your ballasts if you haven't already, I had my capacitor fail on me for 3 days and it took out both my ballasts. Good luck!!
Thank you very much man, I'll look into this tomorrow!
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
