Guidance for a ground point link.. ?
C'mon Guys
battery ground to frame , engine to fire wall, or check dealership . good luck
shows knowledge of the vehicle, and a good sense of being part of a forum.
in my Forum of an older, more complicated vehicle, we Masters never would answer a newb like that.
I determine faults first by checking continuity of the lines under testing conditions first. If a new module or switch is needed it is determined as being failed after testing input/output first.
wow.
G100
In the Forward Lamp Harness on the Lower Left of the Radiator Core Support
Power and Grounding Component Views in Wiring Systems
G101
In the Chassis Harness, left side of the engine near the generator
G102 - Except 4.3L
In the Engine Harness, on the left side of the engine block, #3 cylinder area, below the exhaust manifold
G102 - 4.3L
In the Engine Harness, Right Front of the Engine near the Crank Sensor.
G103 - Gas
In the Engine Harness, on the Left Rear of the Engine Block
G103 - Diesel
In the Engine Harness, on the Right Front of the Engine Block
G104 - 4.8, 5.3, 6.0L
G104 - 4.3 and 8.1L
In the Engine Harness, on the rear of the left Cylinder Head
G105
In the Main Battery Harness, Main Battery Ground on the Right Front of the Engine
G106
In the Main Battery Harness on the Right Side of the Engine
G108 - Diesel
In the Engine Harness on the left front of the Engine Block
G109 - Diesel
In the Engine Harness on the Right front of the Engine Block
G110
In the Chassis Harness on the frame to the rear of the left front tire.
G200
In the HVAC Harness, on the Right Side of the I/P Near the A-Pillar Below the I/P Top Cover
G203
In the I/P Harness, On the Left Side of the I/P Near the A-Pillar Below the I/P Top Cover
G302
G304
In the Body Harness, Under the Passenger Seat
G305
In the Body Harness, Behind the Drivers Side B-Pillar Trim Near the Bottom
G306
In the Body Harness, Behind the Passengers Side B-Pillar Trim Near the Bottom
G390 (Crew Cab w/Rear Window Defog)
Defogger Grid Harness, Near C-Pillar
G401
In the Chassis Harness, On the Spare Tire Hoist Assembly
G402 (Export Only)
In the Chassis Harness, Near the Rear Bumper Assembly
G403
In the Chassis Harness, Near the Left Rear Body Mount
G410
In the Body Harness, Right Rear Interior of Vehicle Behind the Right Side Cargo Area Trim Panel
here's a few ...
  • 3 years later...
Okay so I get it's probably in these forums always confuse me I'm looking for the ground points on a 2005 GMC Yukon I get that they're probably listed in this topic down there. It's the Five Point three it's a Yukon XL I just need the right diagram I appreciate it. Also when I searched diagram a lot of them I don't know how to read some of them are okay is there another way I should word that to find something I can read myself?
Edited by Ty Myers
  • 2 years later...
need ground circuits engine compartment I have installed a new. Motor and must be missing one cause I have no spark or injection pulse, thought it might be vats , but no flashing light for it and no trouble codes
On 3/17/2016 at 12:47 PM, Cosmic Charlie said:
G100
G101
G102 - Except 4.3L
G102 - 4.3L
G103 - Gas
G103 - Diesel
G104 - 4.3 and 8.1L
G105
G106
G108 - Diesel
G109 - Diesel
G110
G200
G203
G302
G304
G305
G306
G401
G402 (Export Only)
G403
G410
here's a few ...
Can’t open any of these files
  • 2 years later...
C'mon Guys
Guidance for a ground point link" typically refers to instructions or recommendations for establishing a connection between electrical or electronic devices via a common ground point. Here's some general guidance:
  1. Identify the Ground Point: Locate a suitable ground point on each device involved in the connection. This is often a metal chassis or designated ground terminal.
  2. Ensure Compatibility: Ensure that the ground points on all devices are compatible in terms of voltage levels and grounding standards to prevent potential damage or safety hazards.
  3. Connect Directly: Whenever possible, connect the ground points directly using a suitable conductor such as a wire or grounding strap. Avoid using intermediary connections or daisy-chaining multiple devices to a single ground point.
  4. Maintain Integrity: Ensure that the ground connection is secure and maintains good electrical continuity. Tighten connections properly to prevent loosening or intermittent grounding.
  5. Minimize Length: Keep the length of the ground connection as short as possible to minimize resistance and interference. Longer ground connections can introduce voltage drops and susceptibility to noise.
  6. Isolation: In some cases, isolation techniques may be necessary to prevent ground loops or interference between connected devices. Consider using isolation transformers or opto-isolators if needed.
  7. Follow Standards: Adhere to relevant industry standards and guidelines for grounding practices, especially in sensitive applications such as electronics or telecommunications.
  8. Testing: After establishing the ground connection, perform thorough testing to ensure proper functionality and to verify that the ground point link meets the required performance criteria.
By following these guidelines, you can establish a reliable ground point link between devices, ensuring proper operation and minimizing the risk of electrical issues.
wow.
It sounds like you have a systematic approach to diagnosing faults in vehicles, particularly older and more complex ones. Forums can be valuable resources for sharing knowledge and expertise, especially when it comes to troubleshooting issues that may not have obvious solutions.
In your forum, it seems like there's a culture of expecting members to demonstrate a certain level of understanding and initiative before seeking help. By checking continuity of lines under testing conditions and assessing the input and output of modules or switches, you're effectively narrowing down the potential causes of faults before considering replacements or repairs. This approach not only saves time and resources but also encourages members to develop their diagnostic skills.
It's important for forums to strike a balance between offering guidance and encouraging self-sufficiency. While it might seem daunting for newcomers to receive less direct answers, it ultimately fosters a community where members learn and grow together, becoming more proficient in diagnosing and fixing issues with their vehicles.
  • 6 months later...
Guys,
while pressing my brakes on my 99 chevy tahoe all my lights on the dashing including gauges turn on and my fuel pump turns on?
anyone know what may be wrong?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
