RC Leveling Kit Issue - Vibration
I had the RC 2 inch front level installed yesterday and also the replacement 2 inch rear block. The install was completed by a reputable alignment shop who also completed an alignment after the install. After the installation I have been able to feel a shake/vibration in my seat and in the gas pedal. The vibration is not over bearing but is noticeable. I cannot pinpoint it to certain point of driving, for example I have felt it through acceleration and while coming to a stop.
Things I have check so far:
- Components removed or loosened appear to be tight although I have not checked torque. By watching the install I don’t think items were torqued to spec even though I included a printout of the specs with the kit.
- I measured the front of the rear axle to where the cab meets the bed. It appear there is ½ to ¾ inch difference between each side.
Before I try to start redoing things or take it back to the shop that did the installation I was hoping to get some feedback from the knowledgeable member of this forum. I read through this forum for a while before deciding to install the level.
The other thing I should mention is I had tires installed the same day the leveling kit was installed by a larger chain tire dealer. I do not think the issue is due to the new tires as it has been consistent between the stock tires and the new tires. I already had the appointment for the tire install so I was unable to address the vibration issue before installing the tires.
Truck is a 2014 Crew Cab LT 5.3 Standard Bed.
If you had no vibration prior to the lift/level, you're most likely dealing with a change in pinion angle due to the change in height. That's where I would concentrate my attention.
However these trucks are very tire sensitive.....
I agree that it's likely an issue caused by change in pinion angle I installed 2" lowering shackles on my 2014 RCSB, and immediately noticed a vibration that wasn't there previously. After installing 2° shims under the rear springs, the vibration disappeared.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,197 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
