Fast headlights fxr GMC retrofit kit
Brand new kit, never installed, everything is still in original boxes, fxr projectors, mirimoto 4300 hids, wiring etc. should be everything you need to install fxrs and hids in GMC projector headlight housings. Pm for more details
  • 1 month later...
Dang, $300 for everything? Incredible price! Bump for someone who needs it.
- Mike
IG: @BlackPearl_Edition
  • 3 weeks later...
Just out of curiosity, why do people change the projectors at all when you can run hid's in the oem projectors?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
