2nd Alignment?
So I will be getting my first rotate and balance of my new tires. The question i have is, will i need to get an alignment as well since i have a leveling kit installed? I got an alignment when i got the kit installed, just don't know if i have to get another with the tires being rotated and balanced.
TIA and Happy Truckin!
If you are just rotating and balancing tires, then no you do not need an alignment. If you had an alignment when the kit was installed your should be good to go.
UNLESS you notice uneven wear on your front tires. Then I would get it checked because it may not be in spec.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 627 Guests (See full list)
