Hitch Mounted Bike Rack
crewl1
I have been looking for a hitch mounted bike rack with a tilt down feature that will allow me to open the tailgate with it installed.
Most that I have seen are either too close to the bumper so even if they tilt they won't let the tailgate open fully, or else are really expensive.
I found the Allen Sports model 552RR Deluxe via Walmart dot com that goes for $79 and it checks all the boxes for me.
The 552RR has a longer hitch section so when tilted the rack provides a 2 inch plus clearance for the tailgate.
"Why do you need a hitch mount bike rack if you have a truck with a bed?" you ask.
For trips to the desert or camping the bed is filled with other stuff so the bikes can't just ride in the bed.
In this shot my landsailer rides on top of the bed and the bed itself would be full of kite buggies and associated equipment.
Funny, I just bought this yesterday and put it together this morning. Good rack for the money!
Sent From My Galaxy S6 Edge+
It holds 4, I can take some in the morning if the op doesn't have any
I only tested with two bikes and didn't get a picture. Here is a video of it loaded up on a different vehicle
Looks like an OK rack for the money. I had the Thule T2 on my FJ Cruiser before, expensive but a great rack. It hold the bikes by the wheels and doesn't scratch the frames if you have fancy or carbon bikes. I'm not sure how I'm going to load my truck yet for trips to the cottage, 2 bikes, 4x8 trailer with the ATV any maybe a couple of kayaks.
I've been in the market for a bike rack, how many bikes does it hold? Do you have pics with bikes on the rack?
Sent from my SM-G930V using Tapatalk
I did a little test fitting, not too bad...thinking about going for the tray style. Nice sturdy rack for the money for sure though.
Crewl1. How has the bike rack held up. Looking to get a hitch mount as well and curious how it is. Is it pretty sturdy?
Sent from my Nexus 6P using Tapatalk
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 979 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
