Anyone know if the running boards that are auto deploying on the Escalade and tahoes fit 2014+ GM crew nab trucks ?
Thanks guys
How do you guys find this part number ?
AMP research. They even offer a plug and play one. GM boards are wired direct through the BCM via the chassis harness. For just the motors, steps, etc. its over $2500 in just parts. AMP will run 1/2 of that maybe more.
Thanks HD driver. Is it safe to say the new 16 GM truck running board that gives bed access is this expensive as well ? I like the amp too and I'm sure I could be flamed for this but I really like the chrome look from the side. And the amp is really hidden and black.
Edited by f8l vnm
Amp makes a chrome add on for the side of the steps
Unless your vehicle came with the auto deploy steps from the factory then you wont be able to add the factory ones at this time, as mentioned they are controlled by the BCM.
It's stainless....
  • 2 years later...
Heres an explanation/video of how pgamboa did his
  • 5 months later...
On 10/16/2018 at 1:03 PM, Hoyt Glagwell said:
I did get a set of Escalade running boards to work on my 16  HD double cab.
Very nice dude! I have the articulating ones on my double cab but prefer the ones you have. Do you happen to know if the wiring harness is the same?
  • 3 years later...
Did you have to swap out the interior switch panel to accommodate the running boards? and did you use Phil Gamboa’s harness? How did you get them to work and fit so nicely? I saw your YouTube vid
  • 9 months later...
On 10/16/2018 at 11:31 AM, Hoyt Glagwell said:
Do you have any information on how the installation was and how you connected all the wiring? Thank you
    1981dustin
    1981dustin
  • Who's Online   2 Members, 0 Anonymous, 1,502 Guests (See full list)
