Torsion Bars...
Archery
I put this in another post..but I figured I would get better response if I put it in its own post.
I had been wondering ...So if I adjust the torsion bars, I will be able to get rid of some of that tilt the Siverado's have that cause it to ride a little lower in the front...?  Is there anything else I need to do? anything to watch out for?
Welcome to the forum,
That "tilt" you refer to is just how the factory sets the front suspension. Adjusting the torsion bars will level it out and get rid of that tilt.
There are a few threads about this throughout the board, you'll find a ton of answers there.
Yeah, give it a few turns to even out the ride, I think it was an 18mm bolt.  Jacking up the front end will make it easier.  Measure the height from ground to frame in a few places before you start, crank them about two turns, ride for a bit to jounce the suspension, measure again, and repeat until you get the desired height, don't go too high though or you'll get a really stiff ride and risk premature wearing of front end components, I'd say an inch to inch and a half.  You may want to get a front end alignment afterwards.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
