DRL's problem.
They also only come on when in gear. The drl lights on my 99 are off in park and neutral.
Make sure you are looking for them with the truck in gear.
+1
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
