Electric Brwiring
:smash: Where is the elctric brake wire located in the cab? I see my 2000 is pre wired back at the rear of the truck but I cannot locate the wire up under the dash. Please help. (Light Blue)
just to the left of the brake there is a black box/cover thing. Pop the cover off and the plug is in there
If you have the factory towing package, the truck is prewired... You will need to get a jumper wire harness from a dealer or RV place, and it plugs into the fuse block as suggested (top row 2nd from the left).
Look closely at the directions and the labels on brake controller wires, because they may not match up color for color with the ones in the jumper harness...
Yeh, its factory wired. I was thinking i needed to wire it up like the old days. I'm off to the dealer to get a "harness" thanks. :smash:
Got it today, thanks for your help.
