Bluetooth for music?
So my 09 has bluetooth, can do voice calls. But I can't control my music from my Android device. What are my options for getting working audio bluetooth? I'd prefer to have the stock controls work too.
Aftermarket deck?
  • 3 weeks later...
Aftermarket deck?
You answered your own question
You can't play music via BT with the factory deck
