you also got it set to a good meshing pattern?
Did you put a Truetrac in your truck also??????
Sent from my LM-G820 using Tapatalk
34 minutes ago, jackgraves said:
Used same Gear. I didn't have to reset pattern
From my understanding of it, changing the carrier can do it, so I would at least check that it has a decent pattern.
Well I'm ok because the marking compound still looked fine on my pattern Thanks for the Concern
No, I haven't.
[emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
My truck came with a G80, but it likely blew up for a previous owner, and they just shoved in an open diff (I noticed this when I changed the rear diff fluid by removing the rear cover, before I discovered it has a drain plug in the bottom of the diff housing).  I used to get stuck in snow a couple of times a year (a lightly loaded dually, in wet snow, doesn't take much to create a rut lined with ice that one side will just spin in), but it hasn't happened since I upgraded the truck to have 4wd, so it would be a bunch of money for something that wouldn't make a significant difference in how the truck operates, as it's not about to do a burnout anytime soon.
  • 3 months later...
On 4/15/2020 at 4:44 PM, jackgraves said:
Ordered Truetrac this morning at 8:05AM
I am interesting in performing a similar upgrade on my 2016 1500 LTZ 4x4 with the G80 9.76" in 3.42 so I would like to get some more information on exactly what you bought. It appears that you got the Eaton Detroit Truetac 914A538 w/ spacer. I assume you also had to purchase a bearing kit and maybe a shim kit. Could you provide some more information?
I bought my truck used with about 29K miles. I noticed right away that the rear diff felt loose but this truck also has the 8L90 which had bad shifting issues (way harsh on downshifts, 3-2, 2-1). The dealership resolved the tranny issues but says "no problem found" on the differential. During a fluid change, I did a visual inspection. I can see the spider gears moving on the differential pinion shaft nearly 1/16" towards the outside of the carrier as a wheel is rotated backwards and forwards. While this may be normal for a high mileage truck, it is surprising to me for a truck with only 30K miles. Rather than argue with the dealership, I figure I would rather just take the opportunity to upgrade to a Torsen style diff and that is why I chose the Trutrac.
  • 6 months later...
On 6/2/2016 at 11:41 PM, Badass69 said:
They won't make one for these rear ends or they would have already. You can just buy this kit here......http://eastcoastgearsupply.com/c-963800-gears-install-kits-carriers-spider-gears-general-motors-gm-9-5-12-bolt.html
The aftermarket for these trucks diffs is a complete fail. At least you can convert the 9.5"..... the 9.76" junk my truck has will never have anything useful for parts made for it lol. Maybe 20 years from now.... but by then who really cares.
I converted my 4x4 6.2 8 speed 9.76 over to 3.73 three years ago. The parts have been out there, just had to do some research. Yes, aftermarket has sucked but I’ve been happy with the AAM carriers and ring and pinion. Eaton is releasing 9.76 TrueTrac early this year so it’s now an option. It does require a spacer though from what I’ve read. I maxed out at 3.73 so I’m not running a spacer. My rear carrier is 23404621.
What are your thoughts on now having the TrueTrac installed?
I am in the same boat as I am converting my 4x4 6.2L 8 spd 9.76 over to 3.73 yet everything is back ordered.  I am currently geared in 3.23 and my shop is saying the 917A732 is the correct part number for 3.42 and higher without having to use a spacer since it has the correct carrier break and we are moving to the 3.73 gears.  Do you happen to remember if you used the 917A732 or 914A538?
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
