LED lights
Just purchased '16' Sierra 1500. I want to convert lights to LED. See some talk on different sites about load resisters on signal lights. Do I have to use them when I convert. Thanks.
First off. What lights are you referring to?
^this and what trim level is the truck?
Sent From My Galaxy S6 Edge+
