Which lift will I need.
Archaic2021
I already have my new wheels and tires. Well..actually will have them in the Morning.
I went with the SOTA Novakane wheels 20x9 with 0 offset anda 305/50r20 Cooper Zeon Ltz. I wanted to keep the height as close to stock as possible so I went with this instead of something taller.
My truck is stock, well actually I pulled the rear block out to lower the rear. Will I need a Leveling kit with the rear block back in for the front or a full 2.5 or possible 3" lift to be able to clear this set up?
I've got 0 offset wheels as well and running 295/55/R20 tires and I barely clear with a 2.5 level and taller rear block. Your tires are wider so you will probably rub. It's not so much the height you need to be worried about as much as the width. I think spacers would help
