Crew Cab rear seat cover
EaZ8
im looking for some sort of rear seat cover that wont get in the way of seatbelts.
the kids make a mess all the time and spill drinks and really they are kids so i dont want to give them crap over a accident...hell it may be because i drove over a bump in the road.
semi waterproof is fine, im planing on spraying it with that rustoleum neverwet just to keep the liquids off the seats and into the foam.
if i had leather i probably wouldnt care as much because well just wipe it off and no smells left behind.
more concerned with the bench section, not the backrest.
anyone have some sort of fitted cover they use for dogs?
Sent from my SM-G930V using Tapatalk
I 2nd the Duluth Trading seat cover. The one I have has lasted through 3 trucks and 8 years. Don't buy anything else.
Sent from my SAMSUNG-SM-G890A using Tapatalk
ide like something a little more fitted.
i wonder what it would cost to have 1 made, or even just get some goretex cut to size with brass eye loops and string it together under the seat.
i doubt ill do that though
Pay $1300 and get some Katzkin leather installed. That's fitted [emoji14]
I can't speak for how rugged they are because I'm not using them for anything to rough. I have a cap so the dogs go in the back but...
Rear Protective Seat Cover
Seatbrella
The back seat cover is the official GM Accessory they sell as the Protective Rear Seat Cover. It's around $300 but I got it as part of a voucher. It's definitely fitted. Dealer installed mine. It actually has a small cut in it under the car seat base. I think the dealer sliced it with a box cutter opening the package but I haven't worried about it since it's a cover and meant to take some abuse. Also most people think it's the leather until I tell them it isn't. I threw in a photo of my Seatbrella for the front seat. I throw them on when I'm sweaty or dirty and they fold into a nice little pouch. I keep one in each door for use as needed.
this is exactly what i want for the rear.a little overkill as it is just kids but it will do the job.
next time im at my dealer im going to try to get a price on one.
i want to get a second vehicle in the next year or 2 (gave 1 away to the inlaws).. it will depend on where me and the wife are working. if we both stay close to home then a car and i want a Tesla model 3 if i end up working far.
if we are both close then i may try to work a deal to get a new car and truck from GM, less options probably the work truck trim but with the work truck floor liners and leather heated seats (aftermarket i guess) and would love the center console somehow.
im fine with the 4x4 on the floor lever.
Weather tech makes a nice one. It fits great. Only problem is you can't use the middle seat belt.
this is exactly what i want for the rear.a little overkill as it is just kids but it will do the job...
I think these work pretty awesome for dogs - https://www.amazon.com/Dog-Seat-Cover-Nonslip-Backing/dp/B00DQFZGZ0/
Normally I like the Clazzio seat covers or sometimes the wet okole's depending on what you are needing them for.
Overall though, protecting your seat is important for your investment. Something comfy for your dog is a must!
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 788 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
