Passenger wiper jet won't work.
Driver side works fine I've tried to unclog passenger side with a computer duster, needle and a compressor. When I used the compressor I saw fluid shoot out of the driver side but when I shoot through the driver side nothing really comes out of the passenger side it just like lightly drops out... Any suggestions?
They are only $4.37 from your dealer I'd just get a new one...
Do you have to take the whole wiper cowl out to replace it?
Per the service manual yes. If you are still in your 3yr/36k bumper to bumper you could take it to the dealer and have them worry about it under warranty.
Ok so I indeed had to take at least half the cowl off just to fit my hand under and come to find out the clip is upside down so rather than doing it from underneath you can actually do it from the top....(used eye glasses flat head) I feel you still have to take the cowl off just because of u don't and lose the hose you are going to be taking it off anyways. Soaked it in vinegar then shot out the clog win a compressor and works like a charm.
I put an old nylon with the toe inside the tank, cut to size and held in place with a zip tie around the neck of the tank. Catches any debris falling into the windshield washer tank. :happysad:
  • 7 months later...
Any tips on removal of the cowl? I have a new to me company truck and the only issue seems to be the same as you- driver side works fine, nothing from passenger side. I would like to tackle this myself so I don't have to wait an hour for the shop to do it, but I don't want to tear anything up.
Thanks.
