Toolbox vs Under Seat Storage
Hello I had my tool box on my truck for 1yr however I been considering moving to an under seat storage due to receiving more space as oppose to a toolbox I have the standard bed so the extra space will help and I like the look without. My question to everyone is would I be making a mistake for going with the Under seat I know my 5 gallon air tank won't be coming with me, but would a 4 way lug wrench and 2 jack stands fit? Please share thoughts and comments if you would stick a toolbox or go with under seat storage. Thanks.
Ps. hope the oem is the best/easiest install.
Install for the OEM is very easy, but it definitely will not fit a 4-way lug wrench and two jack-stands. Dimensions for the Extended Cab one are 60 x 9 x 17 inches:
https://www.amazon.com/gp/product/B00MQ7UCDU/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Don't get me wrong, it's very nice to have, but I don't think it could be used to replace a toolbox.
Thanks for the info, but I have a crew cab hope that increases enough space.
Look into the tuffy box, ive been wanting one for a while now
You could probably get a foldable 4 way lug wrench and 2 jackstands into an underseat storage. It is probably a smaller compartment than you think. I highly suggest seeing one in person before pulling the trigger.
I have one and keep a tool kit, mini air compressor, gloves, paper towels, and some other misc things in there. Still have some room left.
Yeah... I'm in the camp that if you had a foldable 4 way, or a miniature one you could get that under there. And I don't see any type of jack stand fit under there honestly unless there may be some really narrow 3 ton units.
I picked up mine last week and the under seat storage was part of the Costco limited edition package.
I have a first-aid kit under there, a small cardboard box with some little 4oz spray bottles of detail sprays, another box with microfiber towels, a couple of tiny fold up umbrellas and if I'm lucky I can get the OEM windshield sunscreen that folds up underneath there and that's pretty much it.
It's nice to have it there, because it's better than just having loose stuff under the seat ... but it's pretty small overall.
Sent from my SAMSUNG-SM-G935A using Tapatalk
I bought the truck to use the bed, not be taken up a 1/3 of it by a tool box. I have the underseat storage and recently added a battery box under the hood. I have 4 tie downs, football, bungee chords, duct tape, few tools, blanket, seating pad, 30 ft tow strap, 6 ft tree strap, 2 shackles, wheel strap, flashlights and a few other things I can't think of with some space to spare. I will be putting a small portable compressor under there as well (probably an MV 50). It's pretty big, why are you carrying jack stands?
When I leave the city on trips I pack more (small tool set, hi-lift, jumper box, ect) but I don't carry them around with me daily.
Tyler
I have a DuHa and have enough tools to tear the entire truck apart stowed under the rear seat, plus all my winch accessories, straps, jumper cables, etc. When I travel, I throw a box of miscellaneous stuff in the bed...extra fluids, etc.
Sent from my SM-T350 using Tapatalk
I try to keep the floor area clear for when I fold the seat(s) up for secure loading. Do you need to haul this stuff around all of the time or can it be kept in a container (Rubbermaid) and tossed in the back when needed? I have a full width aluminum tool box in the cargo area and keep it pretty empty and available for additional secure storage. I keep basics such as first-aid kit, Leatherman, wipes, tire pressure gauge etc. in lower storage bin between front seats. Tools, trailering equipment or "off the beaten path" supplies are loaded when needed and removed when no longer required. I am retired but when I used a personal vehicle on the job, I removed my tools at night. Unlike other co-workers I never had a window broken by nighttime fortune seekers!
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 407 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
