Stability track/traction control
Just had the 7.5 rcx lift put on my 16' Sierra
I'm having issues when making turns now.
What's happening is the stabilitytrac/traction control kicks in when making turns. It feels like my tires are rubbing when this happens, but it's not! Very annoying.
What can I do to fix this problem?
There was a huge thread on this can't remember the name or link but the 14/15 had this issue you'll have to do some searching If I remember correctly if your using an over sized tire then stock get a wheel size calibrator then I remember reading guys saying it had to do with the alignment of the tires needing to be perfect. Some have had issues some don't. Hope this helps a bit
Sent from my SM-G930W8 using Tapatalk
This absolutely is of help! Maybe it is the alignment? It drives straight as an arrow though. But it wouldn't hurt to double check it for sure.
As far as recalibrating the wheels go, I haven't had this done yet. I have an appointment with my dealership Tuesday to have this done. I really hope this will fix my issue.
Thanks for reaching out man, I appreciate it!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
