04 Yukon - Strange Electronic Noise
creeve4
Recently my Yukon has started making an electronic buzzing type noise. It seems to occur randomly; I cannot reproduce it on demand, neither can I get it to stop other than stopping the vehicle. I've taken it to the dealer several times, they have no idea.
Here are some details, below is a link to a recording I made.
1. The noise only occurs when the engine is running faster than idle.
2. The pitch of the noise never changes.
3. The noise is coming from somewhere behind the glove compartment (I've fully opened it, but cannot locate the exact source).
4. The noise seems to occur more often when it is very hot 95+ F.
5. Sometimes the noise pulses on and off very quickly, other times it is constant for 30 seconds to minute.
6. Sometimes going over a rough bump will start/stop the noise.
Things that have no affect on the noise (don't start or stop the noise):
1. AC/Heater/Fan
2. Radio
3. Cruise control
4. Headlights
5. Turning the steering wheel
6. Speed of vehicle
Any ideas?
Possibly blower fan bearing noise. I've heard them make all kinds of noises from screaming, to chirping.
The way they skimp on grease in bearings these days, it wouldn't surprise me at all if that's what the noise is.
Good idea, I'll look into that, although I don't think it is the blower motor. I have updated my original post with more information.
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,043 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
