2" level to 2.5" level info
Currently I have a 2" level on my truck and I kinda regret not doing the 2.5 level. Does anyone know if I can buy just the top spacer and rear blocks from rough country or would I need to buy the whole kit? If not anyone have part numbers? Thanks all
What are you looking to get out of the .5 of an inch. Seems kind of insignificant.
Look I'm going for. Preference. Wanna clear 33s.
You should on 2in. As long as you don't have a crazy low offset with your wheels
Well my new wheels I'm getting have a 20mm offset. Really would prefer the extra clearance just incase
Mine are +15 and 34" and will barely rub but I'm going with a narrow 34" 275/65-20
I'm gonna run 305/55/20
I don't think you're gonna rub, when I test fit 305/55-20 on a +15 wheel it didn't rub unless I was at full lock turn in reverse. But I understand your point. But that's also why I decided to go with an 11" wide tire instead of a 12" wide tire.
What wheels did you go with?
Kind of plain in comparison. Too late now though, they will be delivered tomorrow.
But the 305/55-20 on my RC 2" level looked like they would clear without rubbing with a +15 offset. I was surprised when it did lightly when in reverse and the wheel turned all the way.
Call rough country. You can buy the upper spacers seperately. I planned on a 2 inch but thought I might as well go with the upper spacer while everything is apart.
29 shipped I believe.
Rear blocks I bought off eBay from motofab.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 524 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
