Forum Log In
Larry
Is anybody else getting sick of logging in every time you visit this forum? Maybe it is just me because my machine is not set up to accept cookies but surely others are getting sick of this.
For the last month or so it is required to log in to read the forums. Why do this? PUTC doesn’t, ColoradoK5 doesn’t, TDP doesn’t, 67-72chevytrucks doesn’t…..come to think of it I know of no other automotive forum that requires a log in just to browse except for this one and your sister sites. Is this a ploy to increase your member base by not allowing just anybody but members browse the forums?
Some of us sneak a peek at the forums while at work on computers that are not set up to accept cookies then reply to threads on our own computers once we get home. It seems unnecessary to make everybody log in just to browse the forums.
The only reason we do this on occasion is to make sure that only members are using up server resources.
We will go back to not having log-ins here soon for a period. Sorry for the inconvenance, and thanks for understanding! :lol:
