Rough country 2.5" vs 2"
Damn that means to be level I have to get the 2.5 in kit and not install the rear blocks to be level.
I think when they are level is when you look at it and think the bed is 1" low. That oversized hood bonnet messes with your eyes
Yup. I read that on another post. 2.5" without the rear block is perfectly level. RC apparently put the block in to keep a little rake. I would take it out if I could swap rear blocks
I did the 2" and it actually is a bit low in the rear. If I were to do it over again I would do the 2.5 hands down.
Since adding the air bags in the back, this is now a moot point. Min pressure keeps it all level again.
Again if were to do that over again, I wouldn't do the bags. Not needed if you have a weight distribution hitch.
