New used truck issue
Gotta vent a little. After searching for a 15 suburban with the options for my wife I found 1 in Connecticut for a gd price. 2 hrs away, dealer very helpfull over phone and made the process of buying easy. Start to drive the car home and service park assist and side assist came on. Really truck has 16000 miles. Get home notice that the radio bezel is cracked. Bit the onstart button to do free trial and says cant connect. Where on a roll here. Go to show my wife how to use the radio and hit has navigation by telematics.
So now contacted the dealer to see what and if anything they are gonna do for me and now have to bring in the truck the 30th to get services. Fml. Other than that 24 mpg and drives nice. It was a fleet vehicle which explains the telematics, so now gonna contact mvi to upgrade the radio or can the dealer do it?
Sent from my SM-G900P using Tapatalk
Fleet vehicle = You nightmare has just started. If it was a GM vehicle, it was likely a buy back that was turned in before the official buy back occurred to keep its record clean. The broken dash often is a sign of unrepaired collision damage. If it was a rent car, remember the golden rule. What is the difference between a rent car and a Jeep? There are some places a Jeep can't go so you rent a car for the off road adventure instead. Sure hope the dealer has a return policy in case this thing turns worse.
CAr still has remainder on warranty. Goin in next week. The dash is fine, its the radio bezel that has a crack in it. Other than that drives nice, but well see
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,298 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
