Starting issues
Have a 2003 Sierra with 4.8L. Has a good battery in it but sometimes even after parked only a few mins the starter will act like the battery is dead. Will do ticking sound but not turn engine. Place booster on in and instantly starts with no lag nothing. Has this happened to anyone here? What can be done to fix it?
Good battery but how old is the starter?
When you are boosting it what do you mean?
Jumping it to another vehicle?
Putting a portable booster on it?
Either way I think the starter is bad, draws more amps than it should so you have to boost it. :happysad:
Not a good battery it has a dead cell...buy a good quality battery and BAM good to go.
Thanks for the info guys. Will check battery negative see if it does good contact with the truck body. If not will have to look at starter I guess. I'm out of town until weekend will update then.
I have a battery tester at home. Battery is good.
None of the electrical stuff in the truck stopped working but the starter would just tic like when a battery is dead.
Used a portable booster pack.
OK my bad, I have had a battery that tested good with my Harbor freight tester until I put my FJC 44118 load tester on it. I always look to the basic easy stuff first Good Luck with it man. Maybe you have discovered a unique and "special" one of a kind problem that no one else in the world has ever seen before................................LOL
Well It was a bad ground from battery to frame. Probably why it started right away with the boost since I plug the ground to the body instead of battery. Bought a ground wire and connected from the battery to a bolt on body and has been starting without issue since.
Thanks for the input.
    Kirk Belch
    Kirk Belch
  • Who's Online   4 Members, 1 Anonymous, 962 Guests (See full list)
