Hypertech Tuner Installed Today = No More AFM!!!!!
GRN69CHV
I've been thinking about a tuner a lot lately. I have 3.42 gears and still want a tune. Good info, thanks. Think I'm about to purchase the same Hypertech.
Responded to a post earlier today talking about this same topic. Have been considering this for a while. Ran out to pick up oil for the tractor today, sure enough Auto store I went to had Hypertech Max Energy #32501 marked down 25% (last one) to $247.00. Checked on-line real quick, this had all the features I wanted, so took it. Installed the prepackaged premium fuel tune, increased trans shift points by 50%, adjusted tire size to 32" for the new shoes and the biggie, turned off AFM. Why did I wait so long to disable AFM. Truck was low on fuel so filled it up with 93 octane, then took it on a 20 mile drive. Even with the crappy 3.08 gears, difference in 6th gear at lower speeds (ie 45 mph and below) when running in V8 mode ( as compared to having it try to run in 6th gear and V4 mode and not do either well) is night and day. There is the option to set a minimum MPH to enable AFM (say 60 mph), but I'd just as soon keep it firing on all 8 cylinders all the time. If I can average 16 mpg in daily rural driving and just touch on 20 mpg highway I will be happy.
How is the sluggish acceleration when you turn corners? Does it feel like your in the right gear and doesn't seem like it needs to down shift when you come out of the turn?
That hasn't changed, I think the tuner focuses on upper part of the power band. With exception of disabling AFM, everything seems to be a change at WOT. Light throttle situation you are describing may be torque management or a change in throttle position. For me, it's a non-issue, I just give it a little more throttle to kick it down into a lower gear. It does seem to be smoother making the transition, only reason I could account for this perception is due to not having the AFM. I know it's supposed to be instantaneous transition from V4 to V8, but I can't help but think the motor has to be running at a higher volumetric efficiency even at low load if firing on all 8 cylinders.
Something else I noticed. Trans is not trying to drop into 6th gear at very low speeds. Wish I would have documented it, prior, when had AFM enabled, it would try to run in 6th and V4 mode at very low mph, often trying to run down the road in 6th gear at about 1000 rpm. Hadn't paid attention to this since the uploading the tune, but realized it was running at about 1200 rpm +/- at about 45 mph - which is 5th gear. It does shift into 6th at about 50 mph.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
