Tuff country 14159 Lift Kit Ordered!
Meethead
I was wondering if the owner of that truck was on this forum. I park in the same garage. I checked it out on a couple of occasions to figure out what lift you were running. Its a good looking truck.
  • Replies 39
Don't do it. I had it on for 3 days. Angles will make you shudder. And the stock midnight 18s will rub the uca.
Why all the problems?
The ride feels the same as factory. I was surprised as my previous truck (ram) had a leveling kit and It felt like a wheel barrel.
I will post pics of the control arm angle and axle angles tonight!
Would love to see pictures of the CV angles. Please post some pictures.
Hey All,
I have an update for you all! Still running like a champ. I do not know what people are talking about. The Truck rides just like it did factory.. I got some Bora Wheel spacers (Hub Centric) as the front tires rubbed a little on the top UCA. And I also wanted the wider stance.
Truck is going great and Aligned no issue. no popping or crunchy sounds. Ready to get Some Boost or Cam in this engine!
N77, Shoot me an IM! I can meet you in the Parking garage to show you the truck if you would like!
I will shoot some more pics of the truck tomorrow as Its going to be 80 degree's out....
Hey All,
Still waiting on those pictures of the CV angles. Pretty please!!!
Also, a question, in the process of installing the strut spacer on top of the strut, does it just bolt on and then you reinstall the strut like normal.Or before you install the spacer does the strut need to be disassembled or unloaded for any reason?
Thank you
Thank you
I have not been able to get under the truck yet. The strut spacer are easy to install. you remove the strut assembly, bolt on the spacer and then just put it back in. no unloading or disassembly required. Once i get home before its night, I will snap a pic!
  • 5 weeks later...
Sorry All I have been busy with the holidays and what nots. The truck is running great, no popping or stiffness on the suspension. I am looking to put some 285/75/R18 Toyo RT's on to compliment the lift. I will shoot some pics of the truck and CV angles and what not this weekend!
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 557 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
