Morimoto Sierra HID kit *help needed*
burnerET
I have a morimoto HID 35 kit installed on my 2015 sierra denali. A couple days ago, one of the headlights (passenger) wouldn't come on. I opened up the hood, everything looked in place. One of the plugs that plugs into actual ballast, the top plastic clips didn't look like they were seated completely. Tried unplugging then replug in, nothing. At this point passenger won't work, driver did. So started trying to trouble shoot. Moved right ballast with left, now the driver is still on, passenger isn't. Ive tried checking the grounds, scraped paint off under them, checked plug connections. Over the past two days, its gone haywire. Sometimes one light( left or right) will come on, sometimes although rarely both, sometimes neither. Anyone got any suggestions or ideas what Im overlooking or missing? Any ideas?
sounds like a power flow or wattage issue. it is not getting enough it sounds like. You should get a volt meter and check what each is recieving at the factory harness plug, the relay and the ballast.
Not sure how Morimoto's wiring harness is constructed but I have a different kit and experienced a similar issue. Knowing that the bulbs and the ballasts were not bad due to the fact that the lights would sometimes work and sometimes wouldn't, I cut the plug connectors off the harness and the bulbs and used butt splices to wire them in. Problem went away and haven't had a problem since. I would not advise doing this until you are sure your issues are not elsewhere.
Here's something you could try to determine if the power flow may be the issue. Mock up a connection to the stock input of the harness and connect that directly to another 12V battery if you have one (by doing this you are supplying a constant voltage to activate the relay on the harness). If you still experience an issue then you likely have some connection issues or faulty components.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
