LED Headlight upgrade
I like the winjet a little better simply because they look like a little better quality over the ANZO. i have heard the anzo can be a real pain to adjust the up and down to position the lights and the quality isn't as nice as you would expect with a $400 + investment. I could be wrong and thats why i value everyones opinion. Thanks for the info on the correct bulb sizes as I did not take that into consideration. Thanks guys!
I heard the same thing about Anzos but I bit the bullet and got a pair about 6 months ago. They are much better light output then my stock lt headlights. They fit great and are just as easy to adjust as the stick head lights which is a pain in the ass lol. I swapped the crappy h7 bulb that came with the anzos stock with the opt 7 LED and it was a great improvement. I wanted a little more then swapped to the morimoto elite hid system and it's perfect in my opinion now!
Was looking at these headlights with an HID kit or the LED. Sounds like the Morimoto kit is the way to go.
What headlights are those and have you installed them?
Hey Alexantics, are the LED's your using super bright and annoying to oncoming traffic. Ive heard the LED can be a bit much as the light is extremely bright and hard to look at....?
I have LED's in my hi beam reflectors and yes, they are blinding to look at for oncoming traffic if I forget to dim them. The reflector doesn't focus the light like a projector does so looking at them is quite bright. It's not that the down range light is extremely bright, actually it's a little disappointing, but still too bright to look at.
On a side note. Does anyone know if HID's do any better at down range light in a reflector than an LED does? The LED does a good job lighting everything up about the same distance as my HID's in the low beam projectors do but not so much down range.
I was using the Opt7 led's. http://www.opt-7.com/fluxbeam-led-headlights/
I got a smoking deal on them form ebay around xmas time. I had them installed in the Anzo projector headlights and i liked them. The Opt7 led fit in the headlight housing with out a need to drill or modify the cap and were plug and play. I liked them so much in fact that I am still using the Opt7 led's as my high beam in the Anzo projectors!
I would not install them in a reflector head light.
https://youtu.be/hRqxTl4rxlg
When you use HID or bright LED's in a reflector you will blind and annoy oncoming traffic even if you adjust your headlights.
Leds and HID's will not annoy other drivers in a projector with a crisp cut off line and not flooding the light everywhere.
Right now I am running a Morimoto Elite H7 HID system for my low beam and the Opt7 H3 for my high beam. I plan on doing a projector retrofit someday to the new Bi-xenon morimoto Mini D2S 4.0 or the Acme Super version H1 if the Mini D2s will not fit in the Anzos
Hmm havent had this issue yet in the year ive run the Opt7 in my reflector. Not one car has brighted me
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
