Weight distribution/sway setup for boat
A couple months ago I went out and bought a project boat. Now I need to tow it safely and thus need a new weight distribution system as the ones I have aren't rated high enough. I'm planning on the total weight of the boat and trailer being 13k, or even a bit over (yes that pushing the limits of the truck). Catch 22 is I can't get it to a scale to weigh it as I still need to put 6 tires on the trailer and my current shank is probably right at it's limit and I know the ball is only 10k, no clue what the head is rated for. Adding to the fun is it's a pole tongue so I'll need an adapter thus reducing my options as well as having surge brakes.
4cd45ac78a162ffc0b53edd5a2ae7be1.jpg is a picture of the mistake. It will be a while before we get it out on the road for actual use, but I need to move it about an hour north of where it is pretty soon.
https://www.etrailer.com/Accessories-and-Parts/Reese/RP58393.html is the pole adapter I think I need and http://www.etrailer.com/comparison.aspx?pc=RP66157&pc2=RP66561are the two weight distribution systems I'm looking at. Going heavier just for when I get a newer truck plus I always like going bigger.
2a80c432c43ebadc211198579234c365.jpg Picture of the boat hooked up to the truck. It was only towed about 2 miles from where we bought it to here and I didn't adjust anything. It's odd seeing one of my trucks sitting level in the back.
So helpful thoughts or suggestions on other systems would be nice since I know there are a lot of you on here that tow.
Thats a nice looking 3500 and boat to. You shouldnt have a problem puling her around with that truck.Sorry I wasnt answering your question but I like your setup.
Thanks, it will be even better when we're done redoing the interior and it's cleaned up. Truck will handle it just fine, just wanting to make sure I do it right. Some of the bridges in Florida get pretty tall and I want some sway control so I don't go flying around when the wind hits these two things that have the aerodynamics of bricks.
I'm not sure your experience with boats but In my experience towing boats for work...I think you'll be fine without wdh.
Towing a boat at about 14500 on a tridem axle trailer with a 3500drw. Been to the scale with it and the tongue was sitting at about 1500lbs. Which is less than the hitch rating.
Truck tows it great. I've never felt anything resembling the sway that I feel while towing my rv with my 1500. Boats just seem to tow so much nicer.
Sent from my SM-G920W8 using Tapatalk
That's pretty much the extent of my boat towing.
Certainly be cheaper to not get a WD set up with sway. Just seems weird to me not have have the bars and stuff. Other problem seems to be, at least on etrailer, limited to 14k trailer weight for the pole frame adapter. Decided since a new hitch is under $300 I might as well get a beefier one that handles more weight.
Most trailers that heavy are expected to be a gooseneck or 5th wheel...you have something out of the norm and that's why you are funding limited options.
What is the rating of your current receiver? If the weight is within the specs of the receiver, then I would look into ball mount options as its very unlikely you would exceed the tongue weight of your 3500. Solid ball mounts can be had for even 2 inch receivers that are rated at 20k pull, 2000 tongue, and the balls for a gooseneck can be had for over 30k pull...I know, I have two. If you have a 2.5inch, you options are a lot better.
Factory is 2.5" but only rated 13k at 1500 tongue. I don't remember what the size of the new hitch was I think 2.0." haven't bought anything yet. Still gives me a lot more options not getting the bars and built in sway though so I guess I'm trying that route. If I don't like how it feels we'll weld plates on the tongue instead of that fancy adapter.
That's factory? Interesting, I guess that's the hitch or what the manual says the truck is rated for? Most I've seen is the new ones at 14-15k for towing. The actual hitch rating could be different. Not that I've looked all that hard. Think I read in another thread ford's are 17k or so.
That's 2012 factory 2.5inch...I'm remembering those numbers so might be faulty...but I know it's higher than my truck's rated capacity.
The LMM or 07 to 10 trucks I consider the OEM hitch weak.
I've seen quite a few grumbling about oem hitches. I was looking at the one you have on your 2500 but ended up going with something different. Such a pain to match up hitch, shank, and head ratings. Trailer weights and tongue weights don't match on those components, drives the OCD in me nuts.
Could the factory hitch be replaced with a higher capacity aftermarket?
Yes, ordered a different one this morning.
I know you can get a pole adapter for the Equal-i-zer 4 point hitch.
http://www.equalizerhitch.com/store/index.php?main_page=product_info&cPath=5&products_id=59
I assume you have surge brakes on the trailer. That limits what WDH you can use. The 4 point will work but not sure about others.
The two your are looking at also are fine for surge.
Yeah all priced out it was over a grand. Going to try a few local pulls once the stuff I ordered this morning comes in before I invest that much. Then again if what I bought doesn't work probably end up costing me more than the grand I originally priced out. The joys of life lol
Not for nothing, but the hitch issues are not limited to GM...
While the 3rd Gen Dodge had a hybrid 2" Class 4/5 that worked for most, the 2nd Gen had a 2" Class 3, and most often the rear frame rails bent when the hitch started to fatigue, leaving you with a real mess...there was even a recall that included two extra brackets to stiffen it up. I think most Dodge owners that really towed often changed out to a hitch that was called the "beast" by Reese at that time? That was one of the first 2.5inch receivers offered by the aftermarket.
The manufacturers are only now catching up to the components that are sometimes necessary on these trucks.
Sounds like you have it figured out, good luck!
Sent from my SM-T350 using Tapatalk
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
