Please help! 1990 gmc 1500 (5.0, 305) stumbles, hesitates when col
Hi everyone.
I have a 1990 gmc half ton with the 305.
Every time I start it when it's cold it wants to hesitate and stumble upon low rpms.
For example: if I start it when it's cold, put it in gear, hold down on the brake, and slightly hit the gas it wants to die out.
It also shifts hard from first to second when cold.
Once the engine warms up all of the symptoms seem to go away.
Also cranks for a couple seconds before starting.
Truck is also giving code 44 (running lean)
List of parts I've change:
-fuel pump and sending unit
-fuel filter
-02 sensor
-air filter
-plugs
-wires
-cap and rotor
-egr valve
-egr solenoid
-cts tested good
-injectors look to be spraying good
-checked all vacuum lines
-swapped a map sensor from my buddies truck to see if it changed and didn't
-cleaned IAC
Sick of throwing money at this and having no positive results.
Any help would be much appreciated.
Like to get some opinions.
Fuel pressure regulator?
TPS?
Go with an aftermarket CAI your plastic intake runner has a imperceptible crack in it.
I did check the fuel pressure.
It was around 6-7 psi.
Changed out the pump, got her back up to 12 psi.
Noticed a difference on throttle response at higher rpm's, but the cold start problem is still there.
That's why Im thinking it's the fuel pressure regulator on the tbi.
When fuel was tested it was tested before it reached the regulator.
if you pinch the return fuel line you should of seen pressure increase if it is a bad reg
Well I pulled off and disassembled my throttle body.
Pulled apart my pressure regulator and the spring was broke into 4 pieces!!!!
Good deal.
I'll let y'all know how she runs.
Runs like a champ!
Again it was the spring for the fuel pressure regulator.
I appreciate everyone's input and hope that if someone has the same issues as I, they come across this forum.
Thanks again.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 486 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
