Ally Balloon Loan
gmcleer
I am currently leasing a 1500 and have considered getting a 2500 due to the payload of my camper. Anyone have any experience with a Balloon loan? It seems that leasing a 2500 is not a good deal and I really don't want the payments of a 2500 loan. The balloon looks like it could work out like a longer lease in a sense. Any experience or opinions? Do you qualify for all the discounts and rebates of a typical purchase?
You're just defering a certain portion of the payments of the loan until a balloon date at which point the principal balance and interest is due. Your lowering your payments so that you can pay more interest on the same balance and you better hope to hell you're not upside down at the balloon date.
So you will pay more interest? Are you paying interest for the full principal during the loan period, or is interest calculated based on principal - balloon?
You are paying interest on principal, but the idea of a balloon is you make smaller payments upfront so you're not paying principal down as quickly.
Balloons are more typical in the business world as a way of getting access to capital with out a huge monthly payment. You're assuming whatever you're getting the loan for will make you the money needed by the balloon date to payoff the principal, or you'll be able to refi using new collateral.
However your vehicle is a depreciating asset, and so I struggle to see how you wouldn't be upside down in it at the balloon date.
If you're leasing now, why not give some more money away?
Unless the lease is a bussiness write off, I repeat I don't get it. :happysad:
Very similar to an Interest Only loan on a house. Except with the auto loan, you're going to need a bunch of money at a later date, whereas with the home loan, you'll never really pay off the principal.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 874 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
