Driver's Side Door Panel Won't Come Off 2005 Silverado
Alright I took off the screw on the bottom/behind handle/left side/plug thingy on right side/electronic control stuff/plastic parts etc and it still refuses to come off. The bottom is loose but it feels like something else around where the window controls is holding it on however theres no screws behind that part. Ideas before I just take it to a stereo shop? All I want to do is replace one door speaker.
  • 4 weeks later...
