Grille removal
If you search, as I just did, there are literally tons of threads asking the same question or threads detailing how to remove it specifically or in conjunction with another part or install. Use that feature and you will find what you are looking for without creating a new duplicate thread.
Tyler
Did mine a few weeks back. More to do than on a chevy. Remove front few screws from wheel well fender trim (black piece), remove screws from top bumper trim piece which are right in front of front wheels and attach it to fender (i think there were 3 on each side). The bumper trim piece then pops off but you need to be under the truck to reach up and release the tabs. You can then remove 4 lower screws that hold bottom of grille in place. Then pull out plastic retainers from radiator top trim piece and remove screws that hold top of grille in place (4 I think).
This video shows how, you just have to adjust for the part(s) that need removed. It only takes a few seconds in most cases.
Does anyone have diagram or removal instructions for a 2016 Sierra Denali grill?
thx
Carl
Your local dealer might have a kind individual to print you the GM service procedures on how to remove it.
That's why a truck ain't a truck unless it has tow hooks!
thx
Carl
Should be a similar process for the 2016
Sent from my SM-G900V using Tapatalk
I used nylon body tools on the inside clips and it worked really well
Amazon had a custom removal tool for about $5......movable rubber pivot works like a charm in tight places like wheel wells and trunks.....one push and perfect removal with no damage to retainer head or splines. Can't afford to bouger one......Chevy charges $4 a piece for these cheap fasteners (or you can buy more than a hundred from Amazon for less than $20). What a markup!
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,098 Guests (See full list)
