Factory non Bose connection to aftermarket amplifier
Hi all, I'm in the process of piecing together the parts to upgrade my stock stereo system and could use some input. The plan is to replace the front speakers with a set of Alpine SPR 60c components, and the rear speakers with a set of Alpine SPR 60's along with one 10 inch sub in a sealed box. The amp will probably be an Alpine PDR-75 5 channel. My question is concerning the interface between the head unit and amp. I was told by a guy that the stock unit was full range and wouldn't require anything more than an LOC. Another shop told me that I would need either an Audio Controls LC7I or something like the JL Audio Fix 86. What have you guys used successfully to make the interface? Thanks in advance for your help!
For me I'm using 2 locs. I don't know how gm played with equalization but mine so far sounds good. I'm running 3 way active with 3 amps total. 2 precision power amps...a 900.4 which drives my mids (dash speakers ..sundown sa2.75) and midbass (pioneer 1730 component). The 900.4 has low/ high and bandpass so the mids are set to 400 to 4k hertz and on the 1730 I ditched the pioneer passive crossover for the mid bass and have it band passed from 70-400 hertz. The 1730 tweets are ran on an pp i 1000.4 and use the pioneer passive crossover and they sit on the dash at the a pillar aimed at the rearview. I have a jbl gt5-12 in a 1.5 cuff box behind my console and have it amped with and old profile California 600 bridged. The way I wired this is the front signal (fl and fr) are wired to a loc and then of the set of RCA's I split them 3 ways..1 rca to the mid amp, 1 to the tweet amp and 1 to the mb amp. To get the sub I have a separate loc off the factory signal and that rca is to the sub amp. In hindsight a lc7i would have been a little less work but if you plan on really getting a good system wait and get a DSP. Minidsp makes the minidsp 6x8 which can split the signal to 8 CH. That would get rid of the locs, allow you to run active, equalize each ch, time align each channel, run any type of crossover points to each channel....ect. Only 275 and from reading reviews well worth it.
But to the point you were asking....the way mine is set right now...it pounds, sounds very clean and super loud...
Sent from my Nexus 6P using Tapatalk
Translation ...my stereo took a bit to put together..lol
Just use line converter (unless the amp has speaker level inputs). Easiest way to integrate is via factory wiring. Use Metra 70-2057 Amp Bypass Harness on amp output side, Use Metra 71-2107 on amp input side. You only need the green plug/harness.
http://www.metraonline.com/part/70-2057
http://www.metraonline.com/part/71-2107
PS- I tried components up front with tweeter in the dash location, didn't like it. Factory dash location is so far forward and the front door location is so far down that all the mids were buried and very weak, also the tweeters reflecting off the dash were harsh. Guys that have effectively ran components up front are mounting the tweeters on the door trim at the mirror location or on the A-pillar trim piece. I highly recommend the Sundown Audio SA-2.75 as replacement for the factory dash speaker. Have these in mine with Alpine 6x9 Ty-R in front doors. Also, keep in mind, the more power you add, the louder the door chimes will get, there's no way around it without eliminating hands free via splitting front and rear signals off the rear feed only. What you might consider (something I am still thinking about doing once I get some free time) is to split the front signal (dash speakers fed direct from head unit / front door speakers are amplified). Chimes will still be amplified, but it won't be that in your face loud.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,142 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
