Eddie 70 Posted November 18, 2016 Posted November 18, 2016 Does anyone know if they make a transmission pan with a drain plug for our trucks? I know this would make draining the fluid much easier and probably something I would do more often if it were easier. If it had a magnetic plug it could pull the crud out with it or the magnet could be put on the outside of the pan and still catch stuff on the inside.
07Softail Posted November 18, 2016 Posted November 18, 2016 PML makes stock and deep capacity aluminium pans $250+ not sure about stamped steel pan with a plug in it. Buy a plug kit pull the pan and weld the drain plug in the stock pan. I never trusted the bolt together drain plug kits with out welding them in. RT
